RandomName1
Oct 10, 2020Follower
CM1000 not getting Gigabit speed with Xfinity
The Xfinity tech showed upwards of 1 Gig from the wall but I can't get a gig connected directly to the CM1000 modem. Please help.
Oct 10, 2020Guru - Experienced User
What speed are you getting?
What device are you testing on?
What website are you using for test? (if its speedtest.com, try several of their servers, they don't always pick one that can max out the speed). Try speedtest.xfinity.com
Gpai
Oct 18, 2020Aspirant
I am having similar issues. I recently upgraded to gig speed through comcast. The engineer came and tested with his equipment and he was getting gig speed whereas I was not able to through my CM1000.
The version of Firmware is V7.01.01
The connection says Good
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 651000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 37 | 651000000 Hz | 3.5 dBmV | 39.7 dB | 35383176 | 0 | 0 |
| 2 | Locked | QAM256 | 10 | 483000000 Hz | 4.4 dBmV | 41.6 dB | 34227231 | 0 | 0 |
| 3 | Locked | QAM256 | 11 | 489000000 Hz | 4.6 dBmV | 41.6 dB | 34230641 | 0 | 0 |
| 4 | Locked | QAM256 | 12 | 495000000 Hz | 4.7 dBmV | 41.6 dB | 34234480 | 0 | 0 |
| 5 | Locked | QAM256 | 13 | 507000000 Hz | 5.6 dBmV | 41.8 dB | 34238224 | 0 | 0 |
| 6 | Locked | QAM256 | 14 | 513000000 Hz | 6.0 dBmV | 41.8 dB | 34242485 | 0 | 0 |
| 7 | Locked | QAM256 | 15 | 519000000 Hz | 6.6 dBmV | 42.0 dB | 34245954 | 0 | 0 |
| 8 | Locked | QAM256 | 16 | 525000000 Hz | 7.0 dBmV | 41.9 dB | 34249929 | 0 | 0 |
| 9 | Locked | QAM256 | 17 | 531000000 Hz | 7.5 dBmV | 42.0 dB | 34253520 | 0 | 0 |
| 10 | Locked | QAM256 | 18 | 537000000 Hz | 8.1 dBmV | 41.9 dB | 34257380 | 0 | 0 |
| 11 | Locked | QAM256 | 19 | 543000000 Hz | 8.4 dBmV | 41.9 dB | 34260139 | 0 | 0 |
| 12 | Locked | QAM256 | 20 | 549000000 Hz | 8.6 dBmV | 42.0 dB | 34264724 | 0 | 0 |
| 13 | Locked | QAM256 | 21 | 555000000 Hz | 8.3 dBmV | 41.6 dB | 34268838 | 0 | 0 |
| 14 | Locked | QAM256 | 22 | 561000000 Hz | 7.7 dBmV | 41.6 dB | 34272310 | 0 | 0 |
| 15 | Locked | QAM256 | 23 | 567000000 Hz | 7.0 dBmV | 41.5 dB | 34275633 | 0 | 0 |
| 16 | Locked | QAM256 | 24 | 573000000 Hz | 6.3 dBmV | 41.5 dB | 34279322 | 0 | 0 |
| 17 | Locked | QAM256 | 25 | 579000000 Hz | 5.8 dBmV | 41.5 dB | 34286435 | 0 | 0 |
| 18 | Locked | QAM256 | 26 | 585000000 Hz | 5.2 dBmV | 41.2 dB | 34289971 | 0 | 0 |
| 19 | Locked | QAM256 | 27 | 591000000 Hz | 4.8 dBmV | 41.2 dB | 34293616 | 0 | 0 |
| 20 | Locked | QAM256 | 28 | 597000000 Hz | 4.5 dBmV | 41.2 dB | 34297375 | 0 | 0 |
| 21 | Locked | QAM256 | 29 | 603000000 Hz | 4.3 dBmV | 40.8 dB | 34301046 | 0 | 0 |
| 22 | Locked | QAM256 | 30 | 609000000 Hz | 3.9 dBmV | 40.7 dB | 34304945 | 0 | 0 |
| 23 | Locked | QAM256 | 31 | 615000000 Hz | 3.7 dBmV | 40.5 dB | 34308735 | 0 | 0 |
| 24 | Locked | QAM256 | 32 | 621000000 Hz | 3.8 dBmV | 40.6 dB | 34312095 | 0 | 0 |
| 25 | Locked | QAM256 | 33 | 627000000 Hz | 3.8 dBmV | 40.5 dB | 34316098 | 0 | 0 |
| 26 | Locked | QAM256 | 34 | 633000000 Hz | 3.8 dBmV | 40.3 dB | 34319935 | 0 | 0 |
| 27 | Locked | QAM256 | 35 | 639000000 Hz | 3.6 dBmV | 39.9 dB | 34323590 | 0 | 0 |
| 28 | Locked | QAM256 | 36 | 645000000 Hz | 3.4 dBmV | 39.8 dB | 34326994 | 0 | 0 |
| 29 | Locked | QAM256 | 38 | 657000000 Hz | 3.6 dBmV | 39.9 dB | 34330852 | 0 | 0 |
| 30 | Locked | QAM256 | 39 | 663000000 Hz | 3.8 dBmV | 40.1 dB | 34332078 | 0 | 0 |
| 31 | Locked | QAM256 | 40 | 669000000 Hz | 3.7 dBmV | 40.3 dB | 34332913 | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| 1 | Locked | ATDMA | 1 | 35600000 Hz | 43.0 dBmV |
| 2 | Locked | ATDMA | 2 | 29200000 Hz | 43.0 dBmV |
| 3 | Locked | ATDMA | 3 | 22800000 Hz | 42.3 dBmV |
| 4 | Locked | ATDMA | 4 | 16400000 Hz | 40.8 dBmV |
| 5 | Locked | ATDMA | 9 | 40400000 Hz | 41.3 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1, 2, 3 | 41 | 722000000 Hz | 4.5 dBmV | 39.3 dB | 1228 ~ 2867 | 8573472 | 2928532 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 4.8 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| 1 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
Current System Time: Sun Oct 18 20:23:53 2020 System Up Time: 0:13:19
The event logs have the following issues
| Time | Priority | Description |
| 2020-10-18, 20:11:17 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=a0:04:60:fc:4f:50;CMTS-MAC=00:01:5c:b2:02:92;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=a0:04:60:fc:4f:50;CMTS-MAC=00:01:5c:b2:02:92;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:4f:50;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
Can someone help explain what the issue is with me not getting Gig speeds. I max out at 230 to 250 mpbs.
Please HELP.
- GpaiOct 18, 2020Aspirant
I tested directly hardwired through a laptop to my modem.
- FURRYe38Oct 19, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.Factory reset the modem as well.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853- GpaiOct 19, 2020Aspirant
Furrye38,
The ISP provider in this case Comcast came home yesterday and checked the quality of the signal coming inside the home. The was able to remove some issues with some interference and was able to demonstrate through his equipment that the signal was strong and he was gettting more than 1 gig connection for download.
And he connected the modem directly to the incoming RG6 Coax. While debugging by connecting my laptop directly to the modem ethernet out I also did the following
(a) I rebooted the modem several times and tried the connection
(b) Factory reset
(c) Each time waited a few mins (powered off, removed the coax connection, removed power input)
Both did not solve the issue.
I had asked the ISP to reprovision the modem before the Tech came in yesterday and that was not successful either. The only thing I have not done is to as them to reprovision after the tech came to visit. I will try that today and repost and see if it that makes a difference.
Would love for someone more knowledgeable than me to look at the settings I posted and logs and see if there is something they see glaring that I might be able to work with Comcast to fix.
Thanks again to everyone who is helping me resolve this !
Seems like the ISP has checked everything. Seems like the the modem itself maybe the problem. I would get another modem put in place to see if the problem continutes...
