RandomName1
Oct 10, 2020Follower
CM1000 not getting Gigabit speed with Xfinity
The Xfinity tech showed upwards of 1 Gig from the wall but I can't get a gig connected directly to the CM1000 modem. Please help.
Gpai
Oct 18, 2020Aspirant
I am having similar issues. I recently upgraded to gig speed through comcast. The engineer came and tested with his equipment and he was getting gig speed whereas I was not able to through my CM1000.
The version of Firmware is V7.01.01
The connection says Good
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 651000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 37 | 651000000 Hz | 3.5 dBmV | 39.7 dB | 35383176 | 0 | 0 |
| 2 | Locked | QAM256 | 10 | 483000000 Hz | 4.4 dBmV | 41.6 dB | 34227231 | 0 | 0 |
| 3 | Locked | QAM256 | 11 | 489000000 Hz | 4.6 dBmV | 41.6 dB | 34230641 | 0 | 0 |
| 4 | Locked | QAM256 | 12 | 495000000 Hz | 4.7 dBmV | 41.6 dB | 34234480 | 0 | 0 |
| 5 | Locked | QAM256 | 13 | 507000000 Hz | 5.6 dBmV | 41.8 dB | 34238224 | 0 | 0 |
| 6 | Locked | QAM256 | 14 | 513000000 Hz | 6.0 dBmV | 41.8 dB | 34242485 | 0 | 0 |
| 7 | Locked | QAM256 | 15 | 519000000 Hz | 6.6 dBmV | 42.0 dB | 34245954 | 0 | 0 |
| 8 | Locked | QAM256 | 16 | 525000000 Hz | 7.0 dBmV | 41.9 dB | 34249929 | 0 | 0 |
| 9 | Locked | QAM256 | 17 | 531000000 Hz | 7.5 dBmV | 42.0 dB | 34253520 | 0 | 0 |
| 10 | Locked | QAM256 | 18 | 537000000 Hz | 8.1 dBmV | 41.9 dB | 34257380 | 0 | 0 |
| 11 | Locked | QAM256 | 19 | 543000000 Hz | 8.4 dBmV | 41.9 dB | 34260139 | 0 | 0 |
| 12 | Locked | QAM256 | 20 | 549000000 Hz | 8.6 dBmV | 42.0 dB | 34264724 | 0 | 0 |
| 13 | Locked | QAM256 | 21 | 555000000 Hz | 8.3 dBmV | 41.6 dB | 34268838 | 0 | 0 |
| 14 | Locked | QAM256 | 22 | 561000000 Hz | 7.7 dBmV | 41.6 dB | 34272310 | 0 | 0 |
| 15 | Locked | QAM256 | 23 | 567000000 Hz | 7.0 dBmV | 41.5 dB | 34275633 | 0 | 0 |
| 16 | Locked | QAM256 | 24 | 573000000 Hz | 6.3 dBmV | 41.5 dB | 34279322 | 0 | 0 |
| 17 | Locked | QAM256 | 25 | 579000000 Hz | 5.8 dBmV | 41.5 dB | 34286435 | 0 | 0 |
| 18 | Locked | QAM256 | 26 | 585000000 Hz | 5.2 dBmV | 41.2 dB | 34289971 | 0 | 0 |
| 19 | Locked | QAM256 | 27 | 591000000 Hz | 4.8 dBmV | 41.2 dB | 34293616 | 0 | 0 |
| 20 | Locked | QAM256 | 28 | 597000000 Hz | 4.5 dBmV | 41.2 dB | 34297375 | 0 | 0 |
| 21 | Locked | QAM256 | 29 | 603000000 Hz | 4.3 dBmV | 40.8 dB | 34301046 | 0 | 0 |
| 22 | Locked | QAM256 | 30 | 609000000 Hz | 3.9 dBmV | 40.7 dB | 34304945 | 0 | 0 |
| 23 | Locked | QAM256 | 31 | 615000000 Hz | 3.7 dBmV | 40.5 dB | 34308735 | 0 | 0 |
| 24 | Locked | QAM256 | 32 | 621000000 Hz | 3.8 dBmV | 40.6 dB | 34312095 | 0 | 0 |
| 25 | Locked | QAM256 | 33 | 627000000 Hz | 3.8 dBmV | 40.5 dB | 34316098 | 0 | 0 |
| 26 | Locked | QAM256 | 34 | 633000000 Hz | 3.8 dBmV | 40.3 dB | 34319935 | 0 | 0 |
| 27 | Locked | QAM256 | 35 | 639000000 Hz | 3.6 dBmV | 39.9 dB | 34323590 | 0 | 0 |
| 28 | Locked | QAM256 | 36 | 645000000 Hz | 3.4 dBmV | 39.8 dB | 34326994 | 0 | 0 |
| 29 | Locked | QAM256 | 38 | 657000000 Hz | 3.6 dBmV | 39.9 dB | 34330852 | 0 | 0 |
| 30 | Locked | QAM256 | 39 | 663000000 Hz | 3.8 dBmV | 40.1 dB | 34332078 | 0 | 0 |
| 31 | Locked | QAM256 | 40 | 669000000 Hz | 3.7 dBmV | 40.3 dB | 34332913 | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| 1 | Locked | ATDMA | 1 | 35600000 Hz | 43.0 dBmV |
| 2 | Locked | ATDMA | 2 | 29200000 Hz | 43.0 dBmV |
| 3 | Locked | ATDMA | 3 | 22800000 Hz | 42.3 dBmV |
| 4 | Locked | ATDMA | 4 | 16400000 Hz | 40.8 dBmV |
| 5 | Locked | ATDMA | 9 | 40400000 Hz | 41.3 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1, 2, 3 | 41 | 722000000 Hz | 4.5 dBmV | 39.3 dB | 1228 ~ 2867 | 8573472 | 2928532 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 4.8 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| 1 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
Current System Time: Sun Oct 18 20:23:53 2020 System Up Time: 0:13:19
The event logs have the following issues
| Time | Priority | Description |
| 2020-10-18, 20:11:17 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=a0:04:60:fc:4f:50;CMTS-MAC=00:01:5c:b2:02:92;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=a0:04:60:fc:4f:50;CMTS-MAC=00:01:5c:b2:02:92;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=a0:04:60:fc:4f:50;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
Can someone help explain what the issue is with me not getting Gig speeds. I max out at 230 to 250 mpbs.
Please HELP.
Gpai
I tested directly hardwired through a laptop to my modem.
