jeffbaygents
Dec 23, 2019Aspirant
cm1000 or cm1000v2 verification before buying
My ISP has a full certification of approval for the cm1000v2. It permits the cm1000; however, it's considered "allowed" and not certified. After a bunch of reading, I've learned that there is a sli...
- Mar 06, 2020I understand either will work...but spectrum seems to like to blame all the internet problems on the equipment..so If you buy the one that is fully ok on their list they cannot use that for an excuse. Netgear should exercise a little common sense and label the sticker what version it is instead of a lottery
Alonewolf85
Mar 06, 2020Initiate
Net Gear has the worst customer service I have ever experienced in my life.. cm1000 vs cm1000v2...they say ask the store and they will tell you..I explained best buy couldn't that there is no marking on the package...Netgears response is go to Walmart and ask them! I asked what is the difference between the 2 her reply is its upgraded! Uhgggg last netgear product I purchase from here on out!
Mar 06, 2020Guru - Experienced User
Probably nothing you'll never notice or deal with. Best recommendation is to look at your ISPs supported modem list. Get either one from a store with a good return policy. Contact the ISP and have them assoicated with there service. If it doesn't work, then you can return the modem.
