jeffbaygents
Dec 23, 2019Aspirant
cm1000 or cm1000v2 verification before buying
My ISP has a full certification of approval for the cm1000v2. It permits the cm1000; however, it's considered "allowed" and not certified. After a bunch of reading, I've learned that there is a sli...
- Mar 06, 2020I understand either will work...but spectrum seems to like to blame all the internet problems on the equipment..so If you buy the one that is fully ok on their list they cannot use that for an excuse. Netgear should exercise a little common sense and label the sticker what version it is instead of a lottery
DarrenM
Mar 06, 2020Sr. NETGEAR Moderator
Hello Alonewolf
The two modems will perform almost the same there are just some minor hardware changes in the units.
DarrenM
Alonewolf85
Mar 06, 2020Initiate
- jeffbaygentsMar 06, 2020Aspirant
Thanks for your comments. I haven't had issues with Netgear Support over the years but what you say about being precise in getting a compatible modem from the ISP's list is correct. I've learned over the years, if I maintain compatibility, it ends discussions on hardware and the ISP immediately tends to resolve any issues rapidly. When I rcvd the Netgear modem eventually, it was then verified as being version 1, which means it had the earlier chipset that doesn't work as well. It was conveyed that there were some issues they couldn't resolve fully on v1 but they can get it all to work w/v2. So, I returned the modem and never could find a confirmed seller of v2. I immediately paid a little more and rcvd the Motorola MB8600, which was on the Spectrum's fully compatible listing. It has been great with full speeds up and down with no issues for 2 months now. Thanks to everyone for their responses and comments. Yours was the truest reply in that it does remain important (for less issues) to stay with compatible hardware when it's clearly stated for a service.
