jammurp
Oct 15, 2020Aspirant
CM1000 performance issues after 1.5 years
Has anyone noticed issues with the CM1000 performance after awhile of having it running? I got mine at best buy just over a year ago and now it seems like it keeps having connection issues. I thought...
Oct 15, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Try a different power adapter with same voltage and amps.
- jammurpOct 15, 2020Aspirant
Thanks, I will look into those suggestions.
