cc22
Feb 09, 2020Tutor
cm1000 power levels
Hello, I've been having issues with my Internet since switching to gigabit with Xfinity in May of 2019. I recently switched from an Arris SB8200 to the CM1000 and saw an almost immediate improvement....
- Feb 09, 2020
You've got a lot of errors in your line. Something to keep in mind is that the cable connections page is a snap shot at the time you accessed it. The power levels can vary a bit. They should be withing 3.5dbmv of each other. You've got a range from -6.9 to -12. so roughly 5.1dbmv range.
What I'd do? move the modem (temporarily) to right where the coax enters the home. Then run the same test and repost back here. If the levels are good, its something within the home such as wiring/connector/etc. If the levels still aren't decent, then xfinity needs to look at the wiring external to the home.
cc22
Feb 09, 2020Tutor
After moving the modem, the power levels changed as shown ranging from 0.6 to 5.1 bringing it closer to the 3.5 but still not there. Upstream dBmV 46.3, 47.0, 47.3.
Feb 09, 2020Guru - Experienced User
No errors so far. Watch it for a bit and see how the errors do. Power levels much better
- cc22Feb 09, 2020Tutor
No more error messages so far. This seems to have fixed it. I extended the line to get the modem where it needs to be for now until Comcast can get out here to run the new cables. Power from -1.7 to 3.6! Nothing showing in the event log! Thank you so much!
- plemansFeb 10, 2020Guru - Experienced User
Glad to see its working better!
Not sure about your area but in my area, comcasts charges to run cables within the home. Exterior to the home, they don't. something to keep in mind is that if the problem is the wiring in the home and they're going to charge you $75 to fix it, it might be cheaper to try replacing some coax ends (usually whats bad), check for kinks, replace splitters/etc.
