Justin81
Dec 21, 2017Aspirant
CM1000 slow Ethernet , faster WiFi - comcast 1 Gig
Hi, I’m a Comcast customer, just bought the 1 Gig Internet, and bought a CM1000 and Google WiFi. I’m getting roughly 160 mbps down via Ethernet and 500 mbps down via WiFi. Comcast is at a complete ...
vkdelta
Dec 22, 2017NETGEAR Employee Retired
always verify it directly connected to CM1000 after a fresh power cycle to confirm you are getting close to a gigE performance.
Justin81
Dec 22, 2017Aspirant
I did that - and it didn’t help.
- vkdeltaDec 22, 2017NETGEAR Employee Retired
what speeds do you see with your PC directly connected to modem?
is your PC/Laptop spec high-end and you are not using USB<>ETH adapters?
Please post connection table from the modem.
- Justin81Dec 22, 2017Aspirant
I'm using CAT 5 cable. I have a Surface Pro 3 PC running W10. My wireless router is a brand new Google WiFi. My wired connection speed is roughly 100-150MBPS today, and my wireless is 500MBPS. I'm paying for 1 Gig.
When I run ipconfig here's what it shows for Ethernet.
IPv4 Address. . . . . . . . . . . : 172.20.35.209
Subnet Mask . . . . . . . . . . . : 255.255.255.240- vkdeltaJan 03, 2018NETGEAR Employee Retired
First thing you want to do is check the wired speeds directly on the modem without any google wifi. if you are getting 500 Mbps in wireless, you should be ATLEAST getting 500 Mbps on wired as well (if not way more).
Can you please confirm hard wired speeds connecting directly to CM1000? (remember to reboot the CM everytime when you connect PC vs Router behind it)
