Justin81
Dec 21, 2017Aspirant
CM1000 slow Ethernet , faster WiFi - comcast 1 Gig
Hi, I’m a Comcast customer, just bought the 1 Gig Internet, and bought a CM1000 and Google WiFi. I’m getting roughly 160 mbps down via Ethernet and 500 mbps down via WiFi. Comcast is at a complete ...
Justin81
Dec 22, 2017Aspirant
How do I do disable QoS and the NIC fix? Thanks!
BigQuark
Dec 22, 2017Guide
The QOS setting will be on a menu inside you router. inside you router. Where at really depends on the router model.
To upgrade your NIC Card Driver you'll need to get into windows device manager, find your network adapter and either Auto update or manually update the driver.
Hope this helps.
