kodybr
Sep 03, 2019Aspirant
CM1000 slow speeds with wave
My CM1000 is not reaching gigabit speeds through Wave Broadband in the SF Bay area. When I first started the service 3 weeks ago, we reached 650 mbps but the speeds have steadily declined and have re...
kodybr
I have tested speeds while directly connected to the modem. I am running the tests on my desktop pc with an i7-6770k and an Asus Maximus Hero VIII with a gigabit network port built into the mobo. I have also done tests directly through my router when it is plugged into the modem and I get the same speeds. The router I have is an Asus R7500-200NAS NightHawk X4 Dual Band Router (AC2350)
Sep 03, 2019Guru - Experienced User
So you don't see anything near 900Mbps with a direct connected PC?
Might try another modem...
