MYT
Sep 29, 2020Follower
CM1000 solid ethernet orange light only
After about a year of use, my CM1000 went dead. When I plug in the modem to power, all the lights blink once, and then the orange ethernet light stays on solidly. I've tried factory reset button, bu...
Sep 30, 2020Guru - Experienced User
Read the user manual on the front LED indiacator meanings.
Disconnect the ISP coax cable from the modem them factory rest.
Try a different power supply. Be sure to match the voltage and amps.
