Madlad90046
Sep 21, 2020Aspirant
CM1000 Spectrum ISP dropping every 5-30 minutes
Hooked up new Modem using the same connection I used for the spectrum modem no changes and everything worked fine for years except with 2 people working from home I wanted the multi channel upload. ...
Madlad90046
Here's my event log...
| Time | Priority | Description |
| 2020-09-22, 05:04:04 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| 2020-09-22, 05:03:47 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 13 ; New Profile: 12 13 .;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| 2020-09-22, 05:03:40 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 .;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| 2020-09-22, 05:03:31 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| 2020-09-22, 05:03:31 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| 2020-09-22, 05:03:31 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| 2020-09-22, 04:46:56 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | Ranging Request Retries exhausted;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; |
Sep 22, 2020Guru - Experienced User
Do you have any splitters, attenuators, or amplifiers in line? if so, remove them.
check all the connectors for loose/cheap/bad connections. Check the coax cable for kinks, damage, corrosion, etc.
Preferrably, move the modem to right where the coax enters the home to prevent the wiring within the home being the issue.
try it there.
If it doesn't help, the isp needs to check the line based off your logs and cable connection info.
