Roystempy
Apr 14, 2017Aspirant
CM1000 sync failure
My CM1000, at first, was amazing and didn't have any problems until a few days after when I noticed my internet would cut off after every few hours. The only way to fix this problem was to unplug the ...
eezibleed
May 26, 2017Aspirant
I'm experiencing dropped Internet connections and performance issues.
My plan is to replace the CM1000 with the comcast provided gateway and return this version under warranty. i work remotely and also trade online. i cant have flakey equipment. today the modem died just after the markete opened at 9:35am and cost me several trades.
i reset the modem and re-gained access but lost 15 minutes.
Ovic
Oct 13, 2017Aspirant
For those still having issues with the connection . Enable your IPv6, do a quick auto config, apply it. Once done, reboot your modem. I hope that helps.
O.V.
O.V.
