krgraham
Oct 24, 2017Tutor
CM1000 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Using this modem with Comcast/Xfinity. Recently I started getting log messages "SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing" Download speed it good and everythi...
DarrenM
Oct 26, 2017Sr. NETGEAR Moderator
Have you ran speed tests and ping tests and you are having no performance issues?
DarrenM
krgraham
Oct 26, 2017Tutor
No performance issues at all. Ping tests and speedtests are all up to spec. Only problem shows up in logs and issue that devices which don't have their own date/time settings are apparently receiving erronious values.
- vkdeltaOct 27, 2017NETGEAR Employee Retired
hi, most likely there was maitenance done in your area which brought down CMTS Line card.
Are you seeing this every day ? or just couple of times?
