Tinkeringtj
Mar 31, 2022Aspirant
[CM1000 to Orbi Tri-Band WiFi 5] internet disconnecting
I've had my equipment for 3 years now, and recently my internet intermittently drops. Coax internet and paying for 1Gig (though rarely see anything past 750MBps). Coax is single line to outside box (e...
Mar 31, 2022Guru - Experienced User
If you think its the modem, a screen snip of the cable connections page and the event logs can help with it.
When it happens next time, write down when it happens and get the logs as well. then we can compare the logs with when it happens to see if there's any notices.
What fixes the problem?
Tinkeringtj
Typically I simply shut down my entire rack for a minimum of 60 seconds. This morning, I did 10 minutes. My wife has an idea, but I'm not sure how or if I even want to tackle it. The coax line to the house from the outdoor box is probably (not even sure) 25+ years old and the line in the house might be the same. Sure, next time it dies I'll do more digging. I appreciate the quick response! Honestly wish it would die soon just to appease my curiosity.
- plemansMar 31, 2022Guru - Experienced User
You can screen snip the cable connections page and logs now. It still gives us an idea of how your line connection is.
