Vpkrv8Qcwf5b590
Jun 20, 2019Tutor
CM1000 Troubleshooting
Hello Everyone: I have a CM1000 that I bought when they first came out at the end of 2016. I used it with a 300Mb/s connection and it worked fine. I recently upgraded my connection to 1Gb/s a...
Jun 20, 2019Guru - Experienced User
the cm1000 does indeed work at gigabit speeds. I've got one working with xfinity right now.
The connections page and log would definitly help in trying to find out if theres a problem.
And I know you've had a tech out but they aren't always the greatest or get the correct partitioning file.
when you're testing your speeds, how are you testing them? Here's what I'd recommend.
1. hardwire your computer to your modem to ensure the route isn't causing the problem.
2. Test on multiple sites. Speedtest.net sometimes can't saturate the gigabit speeds. Try speedtest.xfinity.com or speedtest.googlefiber.net I've had good luck with these saturating gigabit.
Vpkrv8Qcwf5b590
Jun 21, 2019Tutor
Hello Plemans:
Thank you for the reply.
Unfortunately I tried all of these troubleshooting steps (prior to the technician arriving) and saw roughly the same results: through the network stack, connected directly to the modem, all major speed test web utilities.
I am really hoping that someone can tell me what a correctly functioning, or malfunctioning, CM1000 should look like on the CM1000's "Bonded Channels" page.
As well, is anyone aware of any firmware issues with the first units? I would have to check the firmware version, but I am sure that it is an early one.
Anticipatory Replies:
- I am testing via network cable, not WiFi.
- I am not testing through a VPN.
- This particular network stack setup worked fine with a 1Gb fiber connection.
Thanks again!
- Vpkrv8Qcwf5b590Jun 22, 2019Tutor
Hello Everyone:
I eventually found a nice reference here:
http://motorolacable.com/whitepapers/cable-connection
- FURRYe38Jun 22, 2019Guru - Experienced User
Your ISP and ISP tech will be able to let you know if the modem is working well or not. They need to check the signal up to the modem. Have a wired PC connected to the modem directly when the tech arrives.
