Vpkrv8Qcwf5b590
Jun 20, 2019Tutor
CM1000 Troubleshooting
Hello Everyone: I have a CM1000 that I bought when they first came out at the end of 2016. I used it with a 300Mb/s connection and it worked fine. I recently upgraded my connection to 1Gb/s a...
Vpkrv8Qcwf5b590
Jun 21, 2019Tutor
Hello Plemans:
Thank you for the reply.
Unfortunately I tried all of these troubleshooting steps (prior to the technician arriving) and saw roughly the same results: through the network stack, connected directly to the modem, all major speed test web utilities.
I am really hoping that someone can tell me what a correctly functioning, or malfunctioning, CM1000 should look like on the CM1000's "Bonded Channels" page.
As well, is anyone aware of any firmware issues with the first units? I would have to check the firmware version, but I am sure that it is an early one.
Anticipatory Replies:
- I am testing via network cable, not WiFi.
- I am not testing through a VPN.
- This particular network stack setup worked fine with a 1Gb fiber connection.
Thanks again!
Vpkrv8Qcwf5b590
Jun 22, 2019Tutor
Hello Everyone:
I eventually found a nice reference here:
http://motorolacable.com/whitepapers/cable-connection
