jjcm1000
Nov 17, 2019Aspirant
CM1000 Unstable Downstream
I recently upgraded my Xfinity to 600 Mbps, since they said Gig Speed would require technicians to come out. Since my old modem was only DOCSIS 3 I picked up the CM1000. After activation everything s...
Nov 17, 2019Guru - Experienced User
it shouldn't cost anything to fix. Comcast is required to provide you a good signal entering your home. They do charge you if the problem is internal to your home. But you're directly connected to the line coming into the house/apartment. So it should be external to that. I'd make them check/fix it as your power levels are off and you've got issues with the line.
So don't just do it for you, do it for the next renter :)
jjcm1000
Nov 19, 2019Aspirant
Initial Xfinity support chat went about as well as expected, they couldn't detect any issues with the line from their end. They suggested connecting my PC directly to the modem and trying a different ethernet cord. Should I be more direct and point out the issues shown in modem diagnostics?
- plemansNov 19, 2019Guru - Experienced User
What I'd do:
1. directly connect modem to line coming in. Make sure there isn't any splitters or anything else attached.
2. Directly connect the pc to the modem.
If issue is still going on or your line connection still looks like your prior post, its either the modem or the line. They might try to say its the modem as that's their go-to response with 3rd party modems. Push the issue stating that their power levels are off and there's to many errors/problems on the modem connections screen.
