EMH
Aug 16, 2021Tutor
CM1000 Upstream Light Keeps Turning Amber
Hello all, I've been trying for weeks to resolve an issue with a Netgear ADT Hub. ADT has been out several times to no avail. I've tried everything but can't seem to locate the problem. The only...
Aug 18, 2021Guru - Experienced User
If you do get issues, pull that amplifiers out and get a snip of your power levels.
Running 58dbmv on the upstream will cause issues.
If your downstream falls into a decent level, you probably don't need the amplifiers.
If you're needing it for tv, you could use a splitter with one leg going to the modem and the other running to the amp.
vkdelta
Aug 21, 2021NETGEAR Employee Retired
This is too high of US power.
Normal D3.0 US spec is 51dBmV
Extended US power can do anywhere from 54dBmV to 56dBmV sometimes.
58dB and that too with 5 US is really pushing it too far.
Need to be reduced to mid-high 40s ideally.
- EMHAug 21, 2021Tutor
OK. Will explore solution in near future. In the meantime, can anyone elucidate the problem hiw US power causes (i.e. what are the symptoms)?
- vkdeltaAug 22, 2021NETGEAR Employee Retired
you will suddenly loose US bonding (and thats why you see Amber US light since it is working in single US channel mode)
AND/OR you will partial US service
AND/OR you see lot of T3/T4 as well when modem cannot push even more power.
