acfc47
Jul 29, 2021Aspirant
CM1000 v2 4/5 lights blinking quickly
I recently got a new CM1000v2 modem, to replace the modem/router combo I had been renting from Cox. After hooking it up, the power light blinks green and the three lights below it blink amber while t...
- Jul 30, 2021
If you checked all that and a different modem is working and the CM is not, i would presume the CM modem maybe faulty. Possible the Power adapter tot he CM could be faulty. Something to try with a different same spec power adapter and see. If this still fails, the CM needs to be replaced.
acfc47
Jul 30, 2021Aspirant
Ok, that makes sense. I did try it (mistakenly) with a different brand new power supply that is 12v 2.5A, like I mentioned earlier. Do you think that would be a sufficient test to know whether the problem is the power supply, or would trying a different 12v 1.5A power supply (which is the spec it came with) be the only way to know for sure?
Again, thanks for your help.
Jul 30, 2021Guru - Experienced User
1amp higher isn't going to make a difference, if there power supply doesnt' change the behavior, then the CM needs to be replance. Something to ask NG about to see what your options are.
