acfc47
Jul 29, 2021Aspirant
CM1000 v2 4/5 lights blinking quickly
I recently got a new CM1000v2 modem, to replace the modem/router combo I had been renting from Cox. After hooking it up, the power light blinks green and the three lights below it blink amber while t...
- Jul 30, 2021
If you checked all that and a different modem is working and the CM is not, i would presume the CM modem maybe faulty. Possible the Power adapter tot he CM could be faulty. Something to try with a different same spec power adapter and see. If this still fails, the CM needs to be replaced.
