Roger313
May 01, 2020Aspirant
CM1000 v2 Modem drastically slows down my speed
Ive been having issues with my modem ever since i bought it. My plan that i pay for with comcast is 300mbps download/ 10 mbps upload. Ever since i bought this modem my speeds are drastically slower, e...
May 01, 2020Guru - Experienced User
Log into the modem and get the cable connection page too.
if you have any splitters, amplifiers, attenuators hooked to the coax line, remove them. hook the modem to right where the coax enters the home.
- Roger313May 01, 2020AspirantPart 1: I’ve checked for that and cant find any.
- Roger313May 01, 2020AspirantPart 2
- plemansMay 02, 2020Guru - Experienced User
So your speed tests are over wireless? (since you stated you didnt' have a device with an ethernet port)
What device are you using?
Are you testing over 2.4ghz or 5ghz?
What router are you using?
How do you know its the modem slowing the speeds and not the router?
