deiro
Aug 03, 2020Aspirant
CM1000 v2 Not Connecting to Internet
Hello I am having touble with my CM 1000 v2 Modem. I had been using this modem since April with no issiues. I moved on Friday and had my ISP (Optimum) set up my internet in my new apartment. That...
Aug 04, 2020Guru - Experienced User
I couldn't see all of the cable connections page info. A screen snip tends to work better.
But from what I could see, you have a lot of errors in your line.
if you have any splitters, attenuators, or amplifiers in line, I'd remove them.
if it doesn't work, you'd want the isp to check the line.
