Silash1997
Sep 20, 2020Aspirant
CM1000 v2 Still Causing Problems
I have been having continual problems with my ISP/Modem on both download and upload speeds. Here is a timeline; Initially I had a COX tech come out to check the issue with my new 1Gbps/35Mbps speed...
Sep 20, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. If the modem has been working well then all of a sudden speeds are slow, then its either a ISP line single issue or something at your PC or external wfi router that needs to be corrected.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Silash1997
Everything is a direct COAX, and I will try to get the COX tech to check all lines.
