Silash1997
Sep 20, 2020Aspirant
CM1000 v2 Still Causing Problems
I have been having continual problems with my ISP/Modem on both download and upload speeds. Here is a timeline; Initially I had a COX tech come out to check the issue with my new 1Gbps/35Mbps speed...
Silash1997
- Silash1997Sep 21, 2020AspirantISP tech is currently here, it looks like what I thought. Which is to much power being put to my modem, and the box needs an attenuator.
- FURRYe38Sep 21, 2020Guru - Experienced User
Hope that helps. Be sure to have to tech check speeds or watch you check speedcs while he's there.
