DOOMZ
Mar 27, 2020Aspirant
cm1000 vs cm12000
Which is the better modem for gaming? What are the differences? Thank you!
Mar 27, 2020Guru - Experienced User
There both good for gaming. The CM1200 has additional WAN Ports for WAN IP address assignments from an ISP. The 1200 doesn't include a router so you'll still need a external wifi router to connect to it.
DOOMZ
Which is faster? Which will give me the best performance for gaming & streaming? Thanks again!
- FURRYe38Mar 27, 2020Guru - Experienced User
They would be about the same. There both broadcom based chip set modems. Use same or very similar chips.
You external router will be what you need to ensure that doesn't impact gaming.
