SoCalLV
Dec 28, 2025Aspirant
CM1000 w/ R7000P
Hi I’ve had my modem and router for a couple of years. Everything was working fine till couple months ago my internet has been buggy. I noticed the modem upstream light will blink green then st...
SoCalLV
Jan 06, 2026Aspirant
| Frequency start Value | ||||||||||||||||||
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | ||||||||||||||||||
| Startup Procedure | ||||||||||||||||||
- SoCalLVJan 06, 2026Aspirant
Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 5 759000000 Hz 8.7 dBmV 42.6 dB 87718698 0 0 2 Locked QAM256 1 735000000 Hz 8.7 dBmV 42.6 dB 91067378 0 0 3 Locked QAM256 2 741000000 Hz 8.7 dBmV 42.6 dB 91074062 0 0 4 Locked QAM256 3 747000000 Hz 8.7 dBmV 42.6 dB 91077750 0 0 5 Locked QAM256 4 753000000 Hz 8.7 dBmV 42.6 dB 91081614 0 0 6 Locked QAM256 9 783000000 Hz 9.1 dBmV 42.7 dB 86854032 0 0 7 Locked QAM256 6 765000000 Hz 8.9 dBmV 42.6 dB 91088677 0 0 8 Locked QAM256 7 771000000 Hz 9.1 dBmV 42.7 dB 91092987 0 0 9 Locked QAM256 8 777000000 Hz 9.1 dBmV 42.8 dB 91096317 0 0 10 Locked QAM256 10 789000000 Hz 9.0 dBmV 42.8 dB 86884902 0 0
