SoCalLV
Dec 28, 2025Aspirant
CM1000 w/ R7000P
Hi I’ve had my modem and router for a couple of years. Everything was working fine till couple months ago my internet has been buggy. I noticed the modem upstream light will blink green then st...
SoCalLV
Jan 06, 2026Aspirant
| 11 | Locked | QAM256 | 11 | 795000000 Hz | 8.9 dBmV | 42.7 dB | 86892372 | 0 | 0 |
| 12 | Locked | QAM256 | 12 | 801000000 Hz | 9.0 dBmV | 42.7 dB | 86899213 | 0 | 0 |
| 13 | Locked | QAM256 | 13 | 807000000 Hz | 9.1 dBmV | 42.7 dB | 86906720 | 0 | 0 |
| 14 | Locked | QAM256 | 14 | 813000000 Hz | 9.2 dBmV | 42.7 dB | 86914866 | 0 | 0 |
| 15 | Locked | QAM256 | 15 | 819000000 Hz | 9.1 dBmV | 42.8 dB | 86922259 | 0 | 0 |
| 16 | Locked | QAM256 | 16 | 825000000 Hz | 9.1 dBmV | 42.8 dB | 86929503 | 0 | 0 |
| 17 | Locked | QAM256 | 17 | 831000000 Hz | 9.1 dBmV | 42.7 dB | 86937175 | 0 | 0 |
| 18 | Locked | QAM256 | 18 | 837000000 Hz | 9.1 dBmV | 42.7 dB | 86944389 | 0 | 0 |
| 19 | Locked | QAM256 | 19 | 843000000 Hz | 9.4 dBmV | 42.9 dB | 86952100 | 0 | 0 |
SoCalLV
| 20 | Locked | QAM256 | 20 | 849000000 Hz | 9.5 dBmV | 43.0 dB | 86959089 | 0 | 0 |
| 21 | Locked | QAM256 | 21 | 855000000 Hz | 9.7 dBmV | 43.0 dB | 86967015 | 0 | 0 |
| 22 | Locked | QAM256 | 22 | 861000000 Hz | 9.7 dBmV | 43.1 dB | 86974503 | 0 | 0 |
| 23 | Locked | QAM256 | 23 | 867000000 Hz | 9.6 dBmV | 43.0 dB | 86980209 | 0 | 0 |
| 24 | Locked | QAM256 | 24 | 873000000 Hz | 9.8 dBmV | 42.9 dB | 86984289 | 0 | 0 |
| 25 | Locked | QAM256 | 45 | 237000000 Hz | 3.9 dBmV | 41.7 dB | 86989349 | 0 | 0 |
| 26 | Locked | QAM256 | 41 | 213000000 Hz | 4.1 dBmV | 41.9 dB | 91159570 | 0 | 0 |
| 27 | Locked | QAM256 | 42 | 219000000 Hz | 3.8 dBmV | 41.8 dB | 91163150 | 0 | 0 |
| 28 | Locked | QAM256 | 43 | 225000000 Hz | 3.9 dBmV | 41.9 dB | 91167130 | 0 | 0 |
| 29 | Locked | QAM256 | 44 | 231000000 Hz | 3.9 dBmV | 41.9 dB | 91170120 | 0 | 0 |
| 30 | Locked | QAM256 | 46 | 243000000 Hz | 3.9 dBmV | 41.9 dB | 91168249 | 0 | 0 |
| 31 | Locked | QAM256 | 47 | 249000000 Hz | 4.0 dBmV | 41.8 dB | 91168939 | 0 | 0 |
| 32 | Locked | QAM256 | 48 | 255000000 Hz | 4.0 dBmV | 41.6 dB | 91168578 | 0 | 0 |
- SoCalLVJan 06, 2026Aspirant
Upstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 36300000 Hz 43.3 dBmV 2 Locked ATDMA 2 29900000 Hz 43.3 dBmV 3 Locked ATDMA 3 23500000 Hz 43.3 dBmV 4 Locked ATDMA 4 16900000 Hz 43.3 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV - SoCalLVJan 06, 2026Aspirant
Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 5 759000000 Hz 8.7 dBmV 42.5 dB 199607454 0 0 2 Locked QAM256 1 735000000 Hz 8.7 dBmV 42.6 dB 202956000 0 0 3 Locked QAM256 2 741000000 Hz 8.7 dBmV 42.7 dB 202962778 0 0 4 Locked QAM256 3 747000000 Hz 8.6 dBmV 42.6 dB 202966329 0 0 5 Locked QAM256 4 753000000 Hz 8.7 dBmV 42.5 dB 202970352 0 0 6 Locked QAM256 9 783000000 Hz 9.1 dBmV 42.8 dB 198742790 0 0 7 Locked QAM256 6 765000000 Hz 8.9 dBmV 42.7 dB 202977433 0 0 8 Locked QAM256 7 771000000 Hz 9.1 dBmV 42.6 dB 202981608 0 0 9 Locked QAM256 8 777000000 Hz 9.1 dBmV 42.7 dB 202985074 0 0 10 Locked QAM256 10 789000000 Hz 9.0 dBmV 42.7 dB 198773699 0 0
