SoCalLV
Dec 28, 2025Aspirant
CM1000 w/ R7000P
Hi I’ve had my modem and router for a couple of years. Everything was working fine till couple months ago my internet has been buggy. I noticed the modem upstream light will blink green then st...
CrimpOn
Jan 06, 2026Guru - Experienced User
Page 6 of the user manual says that the Upstream LED showing solid amber indicates that one upstream channel is locked.
Is "pstream OFDMA" the same thing as "upstream"?
https://www.downloads.netgear.com/files/GDC/CM1000/CM1000_UM_EN.pdf
- SoCalLVJan 06, 2026Aspirant
Hi yes, its the same thing, it just got cut off. How do I unlock it?
