SoCalLV
Dec 28, 2025Aspirant
CM1000 w/ R7000P
Hi I’ve had my modem and router for a couple of years. Everything was working fine till couple months ago my internet has been buggy. I noticed the modem upstream light will blink green then st...
Jan 06, 2026Guru - Experienced User
Can we get the Event Logs page data as well.
Power for some of our channels is too much and too high.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
I'd day get a -3 or -6dbm cable coax line attenuator installed.
SoCalLV wrote:11 Locked QAM256 11 795000000 Hz 8.9 dBmV 42.7 dB 86892372 0 0
12 Locked QAM256 12 801000000 Hz 9.0 dBmV 42.7 dB 86899213 0 0
13 Locked QAM256 13 807000000 Hz 9.1 dBmV 42.7 dB 86906720 0 0
14 Locked QAM256 14 813000000 Hz 9.2 dBmV 42.7 dB 86914866 0 0
15 Locked QAM256 15 819000000 Hz 9.1 dBmV 42.8 dB 86922259 0 0
16 Locked QAM256 16 825000000 Hz 9.1 dBmV 42.8 dB 86929503 0 0
17 Locked QAM256 17 831000000 Hz 9.1 dBmV 42.7 dB 86937175 0 0
18 Locked QAM256 18 837000000 Hz 9.1 dBmV 42.7 dB 86944389 0 0
19 Locked QAM256 19 843000000 Hz 9.4 dBmV 42.9 dB 86952100 0 0
SoCalLV
Jan 06, 2026Aspirant
| 2026-01-06, 21:13:22 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1; |
| 2026-01-06, 21:12:34 | Notice (6) | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 9 13.;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1; |
| 2026-01-06, 21:11:41 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1; |
| 2026-01-06, 21:11:39 | Warning (5) | Dynamic Range Window violation |
| 2026-01-06, 21:11:39 | Warning (5) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1; |
| 2026-01-06, 21:11:39 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1; |
| 2026-01-06, 21:11:38 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1; |
- SoCalLVJan 06, 2026Aspirant
2026-01-06, 21:11:32 Notice (6) DS profile assignment change. DS Chan ID: 33; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1; 2026-01-06, 21:11:30 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1; 2026-01-06, 21:11:25 Notice (6) TLV-11 - unrecognized OID;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2026-01-06, 21:07:13 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
