glavender
Apr 22, 2024Aspirant
CM1000 with Static IP -- how to login so can update firmware
How do I login to my CM1000 cable modem which has Static IP address to update firmware. I thought I would just http:// into the my static IP gateway address, but no response.
- Apr 23, 2024
Good Luck.
Apr 22, 2024Guru - Experienced User
Users with C and CM series cable modems are not allowed to update FW for the modem. All that is done by the ISP:
Is there a problem with your CM series modem?
glavender
Thank you for the response. I guess Grande Communications -- now Astound quit support Static IPs -- so I guess I am stuck with current firmware. Getting certificate errors using SSL in email.
- FURRYe38Apr 22, 2024Guru - Experienced User
Try using DHCP.
Are you connecting with wired PC to the modem or is there a wifi router in between?
Ask the ISP about DHCP and what is needed to be used for the modem and any wifi router or connected PC to the modem. The modem only passes thru traffic from the ISP to the connecting devices. I don't believe FW on the modem would help that. Something to ask the ISP about.
Good Luck.
- glavenderApr 23, 2024Aspirant
I have to have static for servers. Astound does not want to support static anymore after talking to them. Found out the provider has to update the firmware. Plus, they do not support an older modem like the CM1000. Just going to switch to another provider. Thanks for the responses.
- FURRYe38Apr 23, 2024Guru - Experienced User
Good Luck.
