glavender
Apr 22, 2024Aspirant
CM1000 with Static IP -- how to login so can update firmware
How do I login to my CM1000 cable modem which has Static IP address to update firmware. I thought I would just http:// into the my static IP gateway address, but no response.
- Apr 23, 2024
Good Luck.
glavender
Apr 23, 2024Aspirant
I have to have static for servers. Astound does not want to support static anymore after talking to them. Found out the provider has to update the firmware. Plus, they do not support an older modem like the CM1000. Just going to switch to another provider. Thanks for the responses.
Apr 23, 2024Guru - Experienced User
Good Luck.
