Vmdeangelis963
Apr 16, 2020Aspirant
Cm1000 worst customer service ever
I purchased a new cable modem from them two weeks ago. It would not connect or operate. I called them, waited a half hour on hold then took 10 more minutes to identify myself and the product. They tr...
Vmdeangelis963
Yes, several times
Apr 16, 2020Guru - Experienced User
And did they say the modem was not activatable or not reachable?
- Vmdeangelis963Apr 16, 2020Aspirant
Yes as did netgear support
- FURRYe38Apr 16, 2020Guru - Experienced User
Contact the form moderator to see if they can help you out.
Can you return the modem to the place of purchase?
They both said it could not be contacted. And I cannot return to retail where I got it so it is up to netgear
