sleeplessInMN
Jan 04, 2022Tutor
CM1000 Xfinity - random intermittent slowdown then return to normal
Hi, hope someone can help me out here as to what to do, or where to start. I have a CM1000 with an Orbi RBR50 for wireless. We've been getting random drops in speed, where its 200Mbps, then when ...
Jan 04, 2022Guru - Experienced User
got a screen snip of them? I could give you a rough guess at how the values are. Time will tell on the errors though.
Hope it works!
sleeplessInMN
Jan 04, 2022Tutor
- plemansJan 04, 2022Guru - Experienced User
Better, but you still might have some issue.
Your channels should be within 3.5dbmv of each other. Your range is around 5.5dbmv. You can be a bit outside of it but the 5.5 might be a bit to far. And the log is still showing some issues.
So see how it goes.
Check the rest of your connections as well. A loose, corroded, bad, cheap connection can cause variations/issues as well.
