Sinplicity
Feb 28, 2022Tutor
Cm1000 xfinity issue dropping connection
I am having trouble with my connection dropping through out the day comcast tells me my modem is losing its bootfiles or something and that my connection is good on there end I have pulled my modems ...
Sinplicity
Feb 28, 2022Tutor
Here is a snip of my cable connection page
Feb 28, 2022Guru - Experienced User
lots of errors in there. go through what I outlined prior. If it doesn't help or your connection is still the same, then the ISP needs to check the line.
- SinplicityFeb 28, 2022Tutor
Alright I will check the line, comcast sent out a 3rd party to run the line to my bedroom from the box out side the house about 2years ago and its pretty poorly run outside so it would make sense.
