Nicholas_
Feb 02, 2019Aspirant
CM1000 Xfinity issues
I'm getting lag and slow download speed on games
- Nicholas_Aspirant
You didn't give nearly enough information for people here to help you troubleshoot. But for what it's worth? I ran into your post while looking for discussions about Netgear CM1000 and CM1150v modems having problems getting the speed Comcast customers are paying for.
I purchased a CM1000 initially and had problems where it was only getting about 400mbits/sec top speeds despite having the gigabit tier of service from Comcast/XFinity. I switched to the CM1150v since I also have Comcast voice service and realized that modem was essentially a CM1000 with phone jacks on it too, for their voice service.
Same problem though.... Modem can't get over about half the speed I'm paying for, even with a laptop plugged right in the back of it over wired Ethernet that defiinitely can handle 1 gigabit speed.
I still have the XB6 Comcast Xfi gateway they provided when I signed up for gigabit service, and when I set it up instead of the Netgear, I get the speeds I'm supposed to get. A Comcast tech came out and confirmed my line conditions are "excellent", as well -- and couldn't explain why the Netgear modem was so much slower.
I see several other message threads here with the same basic problem, although in at least 1 or 2 situations, it looks like at least PART of the problem was poor signal quality from Comcast. Still, I've done all the troubleshooting steps and know my circuit works reliably at gigabit speed when using the XB6. Comcast insists my Netgear modem was properly provisioned, and the tech even called in to verify that with a level 3 person. I'm about to give up and return this modem, and just resign myself to paying Comcast the stupid monthly modem rental fee -- at least until another product comes out that works better with their system.
- JJNorcalTutor
kingtj, did you make any further progress with your CM1150v?
I'm in pretty much the same place you were. I'm getting mid 500mbps. While I have never seen my laptop attain gig speeds, it is a one year old high end spectre x360, and all available specs indicating I should be good.
I worked with Netgear support once. They pointed to their specs indicating that power should be between -7 and +7 db. I was at 10+. Comcast attenuated and I'm now between 5 and 6.8.
I believe this did improve the speed somewhat, taking me up to mid to high 500s.
I'm very interested in the end of your story.
Thanks!
- jdmotoAspirant
I feel like I'm on the same boat as you guys. I recently updated Xifitnty Gig service and purcashed a CM1100 to handle the new speed, but so far I'm only getting half the speed downstream (500-600mbps) and full upstream speed (40mbps). I've factory reset the modem and Orbi router once, still getting the same issue. Is there a way to check the boot/config file?
I have a tech coming in tomorrow morning to check the line, but i have a feeling the line will not be an issue.
- JJNorcalTutor
jdmoto , just now seeing this. Netgear suggested I return my modem and get a replacement. This did not NOT result in better speeds.
I believe I ran into kingtj's outcome in another thread. I think he returned his modem, as he was definitively able to get gig speeds with another Comcast modem.
I picked up an xFi and local Comcast store, but it did NOT improve my speeds. In fact, slightly slower than my CM1150v.
I'm not sure what I'm going to do next. How did your tech visit go, and did you find finally attain expected speeds?
- jdmotoAspirantJJNorcal, during the tech visit the tech reloaded the firmware into the cm1100. After the update and reboot I was able to obtain the gig speed. 950/40 but only to certain servers. I'm guess this is due to server limits and distance. My connection to Xfinity servers is gig speed.
I'm sorry to hear that your still having trouble...
