Jayhawker
Nov 27, 2019Follower
CM1000 Xfinity
Paying for Gigabit Internet with Xfinity Comcast in the Boulder, CO area and seeing disappointing speeds. When reading directly from the modem the highest I've seen was about 200 Mbps down. I don't expect to get 1000 Mbps down but getting at least half of that is desireable.
1 Reply
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.Be sure your using a multi processor CPU PC. Some older dual cores can't support high speed testing. Quad core CPUs are minimum to start with.
Be sure your using Ooklas installable speed test app. Don't use a web browser as these can effect results.
Try a different PC to be sure.
Disable all background running apps before testing.
Be sure your using a good quality CAT6 LAN cable between modem and PC.
Jayhawker wrote:Paying for Gigabit Internet with Xfinity Comcast in the Boulder, CO area and seeing disappointing speeds. When reading directly from the modem the highest I've seen was about 200 Mbps down. I don't expect to get 1000 Mbps down but getting at least half of that is desireable.
