Legacy11
Feb 19, 2025Aspirant
CM1000v.2 mod Ipv setting needs to be changed from Ipv4 to Ivp6
I recently had to do a factor reset to my CM1000v.2. Prior to the reset it was set to Ipv6. Now it is set to Ipv4. How do I set it back to Ipv6? Thanks in advance for your help.
Feb 19, 2025Guru - Experienced User
There is no configuration changes with in the CM series modems for IPv#. All CM series modems pass thru both protocols to an external connecting device like a external router system that does have configuration features for IPv6 configurations. Check with the router connected to the CM modem for these features.
what router do you have?
Thats what manages you ipv6
