pavsmtm
Jul 09, 2024Follower
CM1000v2 - is this dual band or can I change it to 2.4GHz to connect a camera?
I am attempting to connect a KASA tp-link camera to my network and it requires 2.4GHz. My CM1000v2 is 5GHz. Can I change the router configuration so I can connect the camera? If so, How? I tried to l...
Jul 10, 2024Guru - Experienced User
Its zero band. It has zero wifi or routing capability. what do you have connected o it for wifi?
