PeteH8sXfinity
Oct 19, 2022Aspirant
CM1000V2 and comcast, CM1000 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol
I've been battling disconnects, from 2-10 a day, packet loss, slow speeds. Playing World of Warcraft or Call of Duty becomes unplayable due to normal 50-60ms speeds going to 1100-2000ms+. I've spen...
Oct 19, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
PeteH8sXfinity
