PeteH8sXfinity
Oct 19, 2022Aspirant
CM1000V2 and comcast, CM1000 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol
I've been battling disconnects, from 2-10 a day, packet loss, slow speeds. Playing World of Warcraft or Call of Duty becomes unplayable due to normal 50-60ms speeds going to 1100-2000ms+. I've spen...
PeteH8sXfinity
Oct 21, 2022Aspirant
Ouch thats $180 down the drain.
Oct 21, 2022Guru - Experienced User
Might ask the ISP to remove the modems association with there service. Then re-add it and ensure it's go the right config file sent down.
If you have a friend or family member with a cable ISP, try the CM at a different location to see if the problem follow would be another suggestion.
