Rydaquin
Nov 05, 2024Aspirant
CM1000v2 and RAX54v2 fluctuating download speeds. I go from 900mbps to 30mbps randomly.
I've already contacted my ISP and was told that everything is fine on their end. I've switched out all the ethernet cords to no avail. Any help would be much appreciated.
- Nov 07, 2024
Thanks for the info. I had my ISP come out and they checked and changed the COAX cables. Said I wasn't getting any power and that one of the cables was dead. So far it seems to be working. I'll watch it for 24hr to see if it dips back down or not.
Nov 05, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Is this over a wired or wireless connection for these results? Wireless could result in varied results. Wired is recommended.
Do you see same when ethernet connected directly to the back of the CM modem with out the router being online?
Compare with different device or PC to see if same thing is seen there as well.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- RydaquinNov 05, 2024AspirantThanks for the quick reply Furry. I am currently at work so I'll get that information once I get home. I have tried bypassing the router but plugging directly to the modem with a cat8, no change. It happens on both wires and wireless devices.
- FURRYe38Nov 05, 2024Guru - Experienced User
Ok, if it happens directly connected to the modem, then ISP needs to review what I posted about.
Firmware Version V6.01.07 Time Priority Description 2024-11-05, 20:27:48 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:27:44 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:27:39 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:27:06 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:26:58 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:26:38 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:26:35 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:26:32 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:25:35 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:25:34 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:25:26 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:25:26 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:25:09 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:24:51 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:24:35 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:24:21 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:24:15 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:23:24 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:22:25 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:22:23 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:22:21 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:21:21 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:21:08 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:20:15 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:19:10 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:19:03 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:18:43 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:18:42 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:18:06 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:18:00 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:17:35 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:17:08 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:17:07 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:16:55 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:16:38 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:16:14 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:16:13 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:16:00 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 35 39 40 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:15:52 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 25 26 27 28 31 33 34 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; 2024-11-05, 20:15:45 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 25 26 27 28 33 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:8c:bf:3c;CMTS-MAC=3c:41:0e:1f:da:3d;CM-QOS=1.1;CM-VER=3.1; For the Modems Cable Connections Status it says it's good. Did you want me to copy and paste those charts under Cable Connection?
