Rydaquin
Nov 05, 2024Aspirant
CM1000v2 and RAX54v2 fluctuating download speeds. I go from 900mbps to 30mbps randomly.
I've already contacted my ISP and was told that everything is fine on their end. I've switched out all the ethernet cords to no avail. Any help would be much appreciated.
- Nov 07, 2024
Thanks for the info. I had my ISP come out and they checked and changed the COAX cables. Said I wasn't getting any power and that one of the cables was dead. So far it seems to be working. I'll watch it for 24hr to see if it dips back down or not.
Rydaquin
Nov 07, 2024Aspirant
Nov 08, 2024Guru - Experienced User
Let us know how it goes. Hopefully good to go now.
- RydaquinNov 09, 2024Aspirant
Thank you for the help. Looks like it's all good now, haven't had any drops in speed.
- FURRYe38Nov 10, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
