Frank126
Feb 02, 2022Aspirant
CM1000v2 blinking down stream light
Anyone have a clue what’s going on? Any help would be appreciated. Tried resetting and restarting. Called ISP only said modem is offline. Wondering if modem is just burn out. Time Not Established C...
- Feb 03, 2022Tech came by today and figure out that there was no signal coming in from the outside. He says it appears ISP(Xfinity) was working outside and left some lines disconnected. Leading to many of my neighbors having no internet. I wasn’t aware my neighbors had no internet either. Connected lines back tested connection and everything seems good now.
Frank126
Feb 03, 2022Aspirant
ISP should be coming today to check that. Provision is good. There are no line splitters. I am using RG6 gold plated. I have done many resets and restarts nothing.
Downstream Bonded Channels
Upstream Bonded Channels
Downstream OFDM Channels
Upstream OFDMA Channels
Current System Time: --- --- -- --:--:-- ----
System Up Time: 0:00:31
Procedure Status Comment
Acquire Downstream Channel 0 Hz In progress
Connectivity State In progress Not Ready
Boot State In progress Unknown
Security In progress BPI+
IP Provisioning Mode In progress Unknown
Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords
1 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
2 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
3 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
4 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
5 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
6 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
7 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
8 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
9 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
10 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
11 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
12 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
13 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
14 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
15 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
16 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
17 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
18 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
19 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
20 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
21 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
22 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
23 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
24 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords
1 Not Locked Unknown 0 0 Hz 0 dBmV 0 dB 0 ~ 0 0 0 0
2 Not Locked Unknown 0 0 Hz 0 dBmV 0 dB 0 ~ 0 0 0 0
Feb 03, 2022Guru - Experienced User
Well that would be a problem. All your data on this page is zero'd. There should be values seen here for all these columns. Have the tech look at this page when they get there.
- Frank126Feb 03, 2022AspirantYeah seems like an outdoor cable issue to me. But was maybe thinking my modem is burnt out. Would the values display zero if a bad modem is the culprit?
I’ll show the tech and update here for future reference anyone else can use.- FURRYe38Feb 03, 2022Guru - Experienced User
Anything is possible. I've never seen this page on a bad modem so I don't know for reference.
Try pressing the reset button for 10 seconds then release.
You might take the modem to a friend, nieghbor or family member and connect it there temporarily and see if the page populates at a different location. I would presume the modem could bad if the page values don't populate.
- Frank126Feb 03, 2022AspirantTech came by today and figure out that there was no signal coming in from the outside. He says it appears ISP(Xfinity) was working outside and left some lines disconnected. Leading to many of my neighbors having no internet. I wasn’t aware my neighbors had no internet either. Connected lines back tested connection and everything seems good now.
