rkalinka
Jun 29, 2022Guide
CM1000v2 cannot access 192.168.100.1
How many times did you have to perform the factory reset? I am having the same problem - performed a factory reset as specified in the note - no change in behavior.
- Aug 29, 2022
rkalinka wrote:
Kitsap - I don't think my Netgear modem has those configurations available to it as it's only a Modem (not a router). When I get a minute do more testing on my environment, I'll see if there is a way to drop in a static route on the MODEM (but I don't think so).
That being said, I could always try to put the static route you mentioned on my ROUTER to see if that fixes the issue - certainly a good idea. That being said, I was having the same URL failure problem when I hooked up my laptop directly to the modem (bypassing the router completely) so I doubt putting a static router on my ROUTER will fix it.... but, I will chase this down as anything is possible and I would like to get it working again.
The static route for access to your modem is a configuration you apply to the router.
Jun 30, 2022Guru - Experienced User
But everything is still working well?
Not sure why you can't access it.
If you disconnect the coax and reboot it, are you able to log into it with it disconnected?
rkalinka
Jun 30, 2022Guide
Yes - that is the odd part. My service seems to be performant and working as expected as per my plan bandwidth. I simply cannot see what is going on in the modem if there are any errors or whatnot. While I don't check the devices every day, part of the reason for getting away from Comcast supplied equipment was so that I can see what is going on when there are issues (which is simply not possible with Comcast devices and support - no matter whom you talk to there).
We are working from home today, so I will test one more time what you have asked when I can get a break. BUT - when I performed a reboot yesterday (with unplugged coax), I was able to login and see "not connected". I then screwed the COAX back on and waited a little bit for the modem to join Comcast network again - I refreshed the Netgear UI page - it showed connected. About 3-5 seconds "after" it's connected - all attempts to navigate the UI and/or login to 192.168.100.1 timeout and I can no longer see that admin page no matter what I try.
I'll post back here with updates - hopefully within the next couple of hours if I can, otherwise it'll have to wait until tonight when nobody else is on.
- rkalinkaJul 01, 2022Guide
UPDATE: With everything "working' aside from the netgear UI, I unplugged the COAX only and waited a few minutes. Obviously, I lost my internet connection, but aside from that, I still could NOT get to the Netgear UI.
The next thing I did was reboot the modem (COAX unplugged) - the modem responds and works well on 192.168.100.1 - and shows "cable connection down". I left it like this for about 5 minutes - no issues getting in and out of the modem.
I plug in the modem to COAX - the WebUI shows "cable connected" for a couple seconds then it timesout, i see the ip flips to 192.168.100.10 for a couple seconds, then to a 75.x.x.x IP. I still cannot login to the Netgear modem but my internet service is running fine.
I have got to believe the webUI changes name resolution to some Comcast IP, but i have no way of knowing what it is. And i have got to believe it's feeding information to Comcast via that IP address.
- KitsapJul 02, 2022Master
You may think your internet service is running fine, but your computer is directly exposed to the internet with no firewall. Not a good situation for browsing the internet, accessing e-mail, banking, etc. Your computer is using the Domain Name Servers (DNS) direct from your internet provider to access web pages.
Power down your modem, router, and computer and disconnect the coax from the modem. Connect port 1 of the modem to your router WAN port with an Ethernet cable, connect your computer to a router LAN port with an Ethernet cable. Leave your other hardware disconnected.
Connect the coax to the modem and power up the modem. Give it plenty of time to fully boot and make connections with your internet service provider. Power up your router and give it plenty of time to fully boot. Power up your computer and give it plenty of time to fully boot and obtain an IP address from your router.
Log in to the GUI console of your router. Verify the IP address of the router is 192.168.1.1. If it is not, change the address in the LAN TCP/IP setup and restart your router. Verify the date time on the router is correct. If not, check your NTP settings. Your router should be configured to dynamically get an (external ) IP address from your ISP. You should see the 75.x.x.x IP you mentioned above.
Access to your modem GUI console is dependent on their being a local area network configured and running. With no router connected, you do not have a LAN. Your modem IP address, 192.168.100.1 should be on the label on the bottom.
In your router configuration, you have an option to choose a different IP address. I chose 10.0.0.1.
As many times as you have tried this and not been successful you may have to clear the cache on your web browser. I have a CM2050V and can access the 192.168.100.1 address using either Firefox or Edge in Windows 10. The router in between the two is a Netgear R7800 with a set IP address of 10.0.0.1.
- rkalinkaJul 03, 2022Guide
Kitsap - Thanks for the additional info. I guess I should've been more clear. I didn't leave my Laptop hooked directly into the modem for long - I was only doing that for triage to confirm my router wasn't blocking it somehow. My steady state network leverages my router (with firewall) - so I didn't bypass my home security for long.
That being said, my router doesn't appear to be the issue here - it's separate from the netgear modem and I can see everything on it. I have full control over my network in this regard and can set it to whatever I want much like yourself. Oddly enough though, I see the same behavior from my router's Public Internet IP address as I do when i tried my laptop (when it's hooked in directly) - the modem starts with 192.168.100.1 - then it flips to 192.168.100.10 (for a second) then it flips one more time to the 75.x.x.x IP from comcast and then I can no longer get into the Modem UI at 192.168.100.1 even though I have internet service. As far as I know, the modem has no security on it whatsoever (beyond admin password that I did change away from default by the way) - so I agree, hooking directly into it is no bueno even though I do have a firewall on this machine as well. (I checked my local logs as well with no blockers showing.)
I have cleared cache and tried different browsers on multiple windows machines as well as iPad/iPhone - which is why I tried bypassing my router (temporarily as well). When the modem COAX is disconnected, I can login to it on 192.168.100.1 - with no issues - and for a long time - the UI is fairly responsive, and I can get to all the modem settings when it's in this state. I also looked for some ebedded website configs options to see if some sort of DNS redirect option existed and was enabled - but I don't see anything. As soon as I plug the COAX back into the modem - the ip's flip (as describe above), and then I can no longer get into the modem. This behavior happens whether i go direct to the modem (temporarily) or through my usual router/network config.
Prior to the recent Comcast outage in my area, I was able to see the netgear Modem just fine from my home network so I am not really sure what changed.
If it matters - my home network is 192.168.1.x (with the router being 192.168.1.1) - but this shouldn't really matter as it all communicated correctly. As I understand it, even though I configured Google DNS servers on my router, Comcast will ultimately route it back to their DNS when packets leave my network. They do some goofy things with "shaping their traffic" on the back end that nobody in Xfinity support would truly explain. For giggles, I did try reverting my DNS servers to the Xfinity ones - with no change in behavior.
- KitsapJul 03, 2022Master
This is a good modem firmware address for reference:
Strange behavior with your setup. I helped a friend commission a CM1200 a few weeks ago on Comcast and all works well and as expected there.
Additional information.
From a Windows computer, as an administrator, use the Command Prompt or Power Shell to issue the command: IPCONFIG /ALL.
The return information will show the IP v4 and v6 address of the computer, lease information, and the IP address of the gateway (should be your router). It will also list DNS servers as your router.
Within the router configuration, I recommend you enable IPv6. I am certain Comcast supports it across their network.
For DNS servers, I use a series of Open DNS, Comcast, and Next DNS. These work well for my location. See attached snips.
- morlan52Aug 29, 2022Aspirant
rkalinka did you ever figure out a resolution to this issue? I'm having this exact same issue. Can reboot the modem without the coax plugged in and can access the web configuration interface, but once I connect that cable and internet access is restored I can no longer access and/or ping.
I'm also on Comcast/Xfinity. My internet connection and bandwidth are working as expected otherwise, however I have been having intermittent internet drop issues over the past week and looked further into the modem where I discovered this issue. I suspect that the modem may be having internal issues.
Thanks!
- KitsapAug 29, 2022Master
Setting up a static route within your router has helped some overcome this situation.
See attached.
- rkalinkaAug 29, 2022Guide
morlan52 - I never got this figured out. I had gone round and round with Netgear and Xfinity support with no answer. Netgear indicated that it's something that Xfinity does since THEY are the ones who push firmware updates (and not Netgear). Xfinity has no idea what Netgear is talking about - and you can't get to anyone in Xfinity who has any real technical knowledge to be able to fix the problem. So - i could either PAY for technical support (to still have no answer), or just go purchase another modem at that point.
All in all the modem DOES work and my service is as expected. For the issues you are talking about, I looked on my own home Router (not netgear) for issues and messages (I had a couple gremlins on my network before that I was able to track down.). IE - it usually shows something if there are problems with the ISP not working for a given timeframe as well. So - I just rolled forward with my config while it's all working.
From the Xfinity side of things, the best they can do is run a signal check as well as run a line check - if both of those are OK, then there's nothing Xfinity will really do.
If you find a fix, please let me know!
Kitsap and rkalinka thank you very much for your replies. Adding a static route for this in the router did end up resolving my issue. Interesting, because this was not previously required before for me to access the modem page. Something must have changed recently on Xfinity's end perhaps.
Should be more able to resolve my intermittent internet issues now more easily with visibility into the modem - thank you again.
- FURRYe38Aug 30, 2022Guru - Experienced User
Just curious, what brand and model routers do you have connected to the CM modem?
- rkalinkaAug 30, 2022Guide
Kitsap - Static route did the fix, but I had to do it a little differently than what you showed in your screenshots because my modem and router are separate devices. BUT - adding in a static route to the modem admin page going out the WAN interface fixed the issue.
After some asking around, it appears that XFINITY has a DOCSYS 3.1 modem script that runs once the modem attaches to the XFINITY ecosystem. It's pushed by XFINITY and nothing that you have control over. No idea why it's suddenly a problem, but it does explain a bit of the behavior.
In all cases, the static route was the fix and I can see everything now.
