Azsd22
Jun 14, 2024Aspirant
CM1000v2 Connection Status Good, No Internet
Hi all, I’ve had my equipment for about 18 months, with no issues on Xfinity. I’ve recently moved to a new property with Cox, and haven’t been able to get my connection working over the last 2 days...
Kitsap
Jun 14, 2024Master
Azsd22 wrote:
Hi all,
I’ve had my equipment for about 18 months, with no issues on Xfinity. I’ve recently moved to a new property with Cox, and haven’t been able to get my connection working over the last 2 days. Cox has said everything is working on their end, and within Netgear genie I can see “Cable Connection Status: Good.” All lights on the modem are solid green, with exception of the Ethernet light which is rapidly blinking green. Steps I have taken are:
1) Reset the modem via Cox (5+ times)
2) Reboot the modem myself by unplugging power and coax cable, waiting several minutes, then plugging back in (5+ times)
3) Tried 4 different Ethernet cables
4) Confirmed modem is compatible with my Cox plan (1000mbps, my previous Xfinity plan was 500mbps, if relevant)
Cox has told me there is nothing more they can do, and to contact Netgear. Netgear support asked for $100 to answer my question as the device is too old (I would just buy a new modem instead of doing that…). Any suggestions on additional troubleshooting I can do?
Thanks much - I appreciate it.
With the modem powered on and booted, disconnect the coax and press the recessed reset button on the back. During the boot process, reconnect the coax and let it finish.
It may take more than one cycle to get this to have an effect.
Reboot your router and your computers.
- Azsd22Jun 14, 2024AspirantThanks for the quick response, Kitsap.
I did try this 5 times, but unfortunately no change with the issue- KitsapJun 14, 2024Master
I did try this 5 times, but unfortunately no change with the issueWhat is the brand name and model number of the router you are connecting to your modem?
Does this router have an LED indicator to show internet connection?
- Azsd22Jun 14, 2024AspirantI have a Netgear AX1800 (R6700AX). The internet LED continuously blinks green, turns amber briefly, then goes back to blinking green. It never goes solid.
I’ve also tried directly connecting to the modem via Ethernet without WiFi, which also shows no internet (despite the “good” cable connection status, all lights green except Ethernet, etc). Thank you!
