Azsd22
Jun 14, 2024Aspirant
CM1000v2 Connection Status Good, No Internet
Hi all, I’ve had my equipment for about 18 months, with no issues on Xfinity. I’ve recently moved to a new property with Cox, and haven’t been able to get my connection working over the last 2 days...
Kitsap
Jun 14, 2024Master
A suggestion:
Reboot your modem with nothing connected to the output port.
With your computer powered down, connect an Ethernet cable between the computer and the modem.
Reboot your computer and give it ample time to boot and for the ISP servers to assign an IP address before checking for internet access. This is important the first time with a direct connection. Ample time could be as long as 30 minutes to an hour depending on the ISP.
Azsd22
Jun 15, 2024Aspirant
No luck unfortunately. I did also try replacing the coax cable as well as tried connecting to another coax port within my home.
I’m going to purchase a new modem today, as I think we’ve run out of reboot and reset options to try
- KitsapJun 15, 2024Master
Please report back your results.
