xiimagzx
Aug 16, 2022Guide
Cm1000v2 constant error codes and dropping internet!
I have a cm1000v2 with constant error codes and internet issues..... wondering if I could get some help! I've contacted my isp daily for a year now, my internet and my neighbor's internet goes out si...
Aug 16, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page. Specifically the download section please.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
I see lots of Criticals and correct and uncorrectables on the uplink section that the ISP needs to look into.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
xiimagzx
Aug 18, 2022Guide
how do I get to the download section to copy and paste?
