xiimagzx
Aug 16, 2022Guide
Cm1000v2 constant error codes and dropping internet!
I have a cm1000v2 with constant error codes and internet issues..... wondering if I could get some help! I've contacted my isp daily for a year now, my internet and my neighbor's internet goes out si...
xiimagzx
Aug 18, 2022Guide
Aug 18, 2022Guru - Experienced User
You have lots of correct and un-correctables that should be zeros. Need to check coax cable lines, fittings and remove any splitters.
Have the ISP help you with this if needed.
Follow the posted suggestions.
Can post the Events Log page as well. If you see lots of Criticals or Errors there, the ISP needs to review that and help resolve those.
