CWaters75
Apr 23, 2022Aspirant
CM1000v2 Cox Dropping Internet Connection
Good morning folks. I have been having an issue with my Cox service for quite sometime. The internet will just "vanish", but the Eth0 & WiFi will continue to work fine. At first, thought it was our r...
CWaters75
FURRYe38 - I love the "canned message" on all your responses - LOL. With the amount of times I've read it, I can almost repeat it my memory - LOL HA HA HA I read that a couple months back before I called in for service, and the contractor did in fact test with his meter, and said everything's okay. Now whatever that means, who the hell knows.
Also, there are no splitters or anything. I have a line that goes from the Tap in the Ped about 5 yards tops from the house (which is the line the contractor replaced), to the J-Box which there's only two lines in there. One for the Cable Modem which is right inside the house from the J-Box on about a 4 foot line through the wall, and the other connection which is UNPLUGGED is to the On-Q box in the laundry room, which is unplugged because we don't use anything Cox other than the modem right inside the house from the J-Box. The tech unplugged the Splitter in there and just threw a barrel connector on the lines.
So you are saying the levels I posted in that PDF are too high? What should they be roughly, for someone who is only about 5 yards tops from the Tap with no other devices in line from the Ped Tap to the Modem?
Apr 23, 2022Guru - Experienced User
- CWaters75Apr 23, 2022Aspirant
Yeah sorry FURRYe38. I saw your link, read it as I was typing, and completely forgot to take that out of my post.
So if Cox comes back and says, "Oh - those are completely acceptable", then I guess it just stays sending too much power (two times the acceptable amount according to Netgear), and we just deal with the internet vanishing every couple days... UGH!
I mean I don't know what else to do other than wake up Mon, Wed, and Sat and power cycling the modem to get it to last a couple days.
Now granted, with the amount of new housing and businesses growing here in North Phoenix, they are constantly adding / reconfiguring head-ends, so I guess best case scenario, is open another T-Ticket and ask for an In-House tech this time?
- FURRYe38Apr 23, 2022Guru - Experienced User
Ask them to install a attenuator between the modem and cable jack. This will help bring the power level down some. I have one on mine:
1 Locked QAM 256 1 651000000 Hz 0.0 dBmV 34.9 dB 0 0
2 Locked QAM 256 2 657000000 Hz -0.2 dBmV 34.9 dB 0 0
3 Locked QAM 256 3 663000000 Hz 0.0 dBmV 34.9 dB 0 0
4 Locked QAM 256 4 669000000 Hz -0.2 dBmV 35.0 dB 0 0
5 Locked QAM 256 5 675000000 Hz 0.0 dBmV 34.9 dB 0 0
6 Locked QAM 256 6 681000000 Hz 0.2 dBmV 34.9 dB 0 0
7 Locked QAM 256 7 687000000 Hz 0.0 dBmV 35.0 dB 0 0
8 Locked QAM 256 8 693000000 Hz 0.2 dBmV 34.9 dB 0 0
9 Locked QAM 256 9 699000000 Hz 0.2 dBmV 35.0 dB 0 0
10 Locked QAM 256 10 705000000 Hz -0.2 dBmV 35.0 dB 0 0
11 Locked QAM 256 11 711000000 Hz 0.0 dBmV 34.9 dB 0 0
12 Locked QAM 256 12 717000000 Hz 0.2 dBmV 35.5 dB 0 0
13 Locked QAM 256 13 723000000 Hz 0.0 dBmV 34.9 dB 0 0
14 Locked QAM 256 14 729000000 Hz -0.2 dBmV 35.0 dB 0 0
15 Locked QAM 256 15 735000000 Hz 0.0 dBmV 35.0 dB 0 0
16 Locked QAM 256 16 741000000 Hz 0.0 dBmV 34.9 dB 0 0
17 Locked QAM 256 17 753000000 Hz 0.0 dBmV 35.5 dB 0 0
18 Locked QAM 256 18 759000000 Hz -0.5 dBmV 35.0 dB 0 0
19 Locked QAM 256 19 765000000 Hz -0.7 dBmV 35.0 dB 0 0
20 Locked QAM 256 20 771000000 Hz -0.7 dBmV 35.5 dB 0 0
21 Locked QAM 256 21 777000000 Hz -1.0 dBmV 35.0 dB 0 0
22 Locked QAM 256 22 783000000 Hz -1.4 dBmV 34.9 dB 0 0
23 Locked QAM 256 23 789000000 Hz -1.5 dBmV 35.5 dB 0 0
24 Locked QAM 256 24 795000000 Hz -1.5 dBmV 35.0 dB 0 0
25 Locked QAM 256 25 801000000 Hz -1.7 dBmV 34.9 dB 0 0
26 Locked QAM 256 26 807000000 Hz -1.5 dBmV 34.9 dB 0 0
27 Locked QAM 256 27 813000000 Hz -1.7 dBmV 35.0 dB 0 0
28 Locked QAM 256 28 819000000 Hz -2.0 dBmV 34.9 dB 0 0
29 Locked QAM 256 29 825000000 Hz -1.9 dBmV 35.0 dB 0 0
30 Locked QAM 256 30 831000000 Hz -2.0 dBmV 35.0 dB 0 0
31 Locked QAM 256 31 837000000 Hz -2.2 dBmV 34.9 dB 0 0
32 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0- CWaters75Apr 23, 2022Aspirant
Thank you... I couldn't remember the name of the device that would bring DOWN the signal. 🙂
So question that probably sounds extremely dumb... I know LOW signal level would keep you from acquiring stable signal locks, etc. But, how would twice the power affect the signal making it drop connection until the modem is power cycled? I'm just curious...
Also, with Cox, there's the ability to "Reset Modem" (which most ISP apps have now), and that NEVER works after the modem has been online for a day or so. If I try it the same day I manually power cycled the modem, it'll work all day long. But, let it set for a while, I guess with the signal becoming degraded and whatnot, it doesn't work. Cox can still send a Cold Hit and/or Warm Hit to the modem no matter what and it works.
I just think it's really weird. Never had this happen with too much signal. 🙂
