CWaters75
Apr 23, 2022Aspirant
CM1000v2 Cox Dropping Internet Connection
Good morning folks. I have been having an issue with my Cox service for quite sometime. The internet will just "vanish", but the Eth0 & WiFi will continue to work fine. At first, thought it was our r...
Apr 23, 2022Guru - Experienced User
Ask them to install a attenuator between the modem and cable jack. This will help bring the power level down some. I have one on mine:
1 Locked QAM 256 1 651000000 Hz 0.0 dBmV 34.9 dB 0 0
2 Locked QAM 256 2 657000000 Hz -0.2 dBmV 34.9 dB 0 0
3 Locked QAM 256 3 663000000 Hz 0.0 dBmV 34.9 dB 0 0
4 Locked QAM 256 4 669000000 Hz -0.2 dBmV 35.0 dB 0 0
5 Locked QAM 256 5 675000000 Hz 0.0 dBmV 34.9 dB 0 0
6 Locked QAM 256 6 681000000 Hz 0.2 dBmV 34.9 dB 0 0
7 Locked QAM 256 7 687000000 Hz 0.0 dBmV 35.0 dB 0 0
8 Locked QAM 256 8 693000000 Hz 0.2 dBmV 34.9 dB 0 0
9 Locked QAM 256 9 699000000 Hz 0.2 dBmV 35.0 dB 0 0
10 Locked QAM 256 10 705000000 Hz -0.2 dBmV 35.0 dB 0 0
11 Locked QAM 256 11 711000000 Hz 0.0 dBmV 34.9 dB 0 0
12 Locked QAM 256 12 717000000 Hz 0.2 dBmV 35.5 dB 0 0
13 Locked QAM 256 13 723000000 Hz 0.0 dBmV 34.9 dB 0 0
14 Locked QAM 256 14 729000000 Hz -0.2 dBmV 35.0 dB 0 0
15 Locked QAM 256 15 735000000 Hz 0.0 dBmV 35.0 dB 0 0
16 Locked QAM 256 16 741000000 Hz 0.0 dBmV 34.9 dB 0 0
17 Locked QAM 256 17 753000000 Hz 0.0 dBmV 35.5 dB 0 0
18 Locked QAM 256 18 759000000 Hz -0.5 dBmV 35.0 dB 0 0
19 Locked QAM 256 19 765000000 Hz -0.7 dBmV 35.0 dB 0 0
20 Locked QAM 256 20 771000000 Hz -0.7 dBmV 35.5 dB 0 0
21 Locked QAM 256 21 777000000 Hz -1.0 dBmV 35.0 dB 0 0
22 Locked QAM 256 22 783000000 Hz -1.4 dBmV 34.9 dB 0 0
23 Locked QAM 256 23 789000000 Hz -1.5 dBmV 35.5 dB 0 0
24 Locked QAM 256 24 795000000 Hz -1.5 dBmV 35.0 dB 0 0
25 Locked QAM 256 25 801000000 Hz -1.7 dBmV 34.9 dB 0 0
26 Locked QAM 256 26 807000000 Hz -1.5 dBmV 34.9 dB 0 0
27 Locked QAM 256 27 813000000 Hz -1.7 dBmV 35.0 dB 0 0
28 Locked QAM 256 28 819000000 Hz -2.0 dBmV 34.9 dB 0 0
29 Locked QAM 256 29 825000000 Hz -1.9 dBmV 35.0 dB 0 0
30 Locked QAM 256 30 831000000 Hz -2.0 dBmV 35.0 dB 0 0
31 Locked QAM 256 31 837000000 Hz -2.2 dBmV 34.9 dB 0 0
32 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
CWaters75
Thank you... I couldn't remember the name of the device that would bring DOWN the signal. 🙂
So question that probably sounds extremely dumb... I know LOW signal level would keep you from acquiring stable signal locks, etc. But, how would twice the power affect the signal making it drop connection until the modem is power cycled? I'm just curious...
Also, with Cox, there's the ability to "Reset Modem" (which most ISP apps have now), and that NEVER works after the modem has been online for a day or so. If I try it the same day I manually power cycled the modem, it'll work all day long. But, let it set for a while, I guess with the signal becoming degraded and whatnot, it doesn't work. Cox can still send a Cold Hit and/or Warm Hit to the modem no matter what and it works.
I just think it's really weird. Never had this happen with too much signal. 🙂
- FURRYe38Apr 23, 2022Guru - Experienced User
Too much power maybe overloading the modem and components and causing some over heating as well. Could cause some damage if left unchecked over time.
The reset button should work too reset any modem.
The web pages reboot function should work too soft reboot the modem. However who knows that ISPs can do with there configuration files.
- CWaters75Apr 23, 2022Aspirant
Makes sense FURRYe38... The modem as it is, is a bit too warm to the touch in my opinion. The modem is in an enclosed cabinet right next to my 1TB Western Digital NAS drive with an IDE drive in it. The NAS drive runs a LOT cooler than the modem does.
It's almost like a piece of pizza... The slice you just ate that was chillin on the counter top all afternoon is my NAS drive. The piece you just ate that was in the microwave for 15 seconds is the Netgear Modem.
I understand the web interface and / or reset button work perfectly fine. HOWEVER... When we are on vacation flying to San Diego, Northern Arizona, etc. for lunch, and the internet vanished, there's no way to reboot the modem without calling Cox which I can fly back from Sedona to N. Phoenix faster than I can get someone on the phone at Cox.
Once the power and signal on the line is to spec, you shouldn't have a need for any reboots. Modems are designed to run for days and months 24/7.
